AFR 190 heads and blower
Old Dec 20, 2000 | 09:37 PM
GlenYappa's Avatar
I am still in the planning stages of my "street legal" 350. I have decided to use Weiand's low profile SC. Comp Cams has recommended a cam to use with the blower that will pass emmissions. Weiand suggests around an 8:1 CR for the engine. OK enough of that. I had decided on AFR 190 heads because the exhaust flows so well. It seems the intake port is larger that a stock manifold. The SC is made to replace a stock manifold. I am concerned about the SC mating well with the AFR head. Should I pick another head like an Edelbrock or port the intake manifold on the SC or just not worry about it because I won't be able to tell any difference?
I'm about to spend a lot of money so if anyone sees a massive problem with this engine combo please tell me.
Thanks for the help
Glen
Old Dec 24, 2000 | 08:33 AM
blowen90ta's Avatar
i run a paxton and afr 190's and10-1 compression i think you will be sorrry if you dont at least run 9-1 but thats my .02
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Dec 24, 2000 | 03:21 PM
82z's Avatar
82z
I don't think I would run anything over 8.5 even then.... Have you consulted either AFR or Weiand about the intake. The weiiand intake should fall in place as far as I know. I don't think the AFR heads are to crazy i.e. vortec bolt pattern, raised runner ports, etc.. You should verify that the center bolts are the same angle on both heads and intake. Remember the 87 later angle change. All in all I thing your combo will stomp. The new AFR 190 and 195 really rock. I drooled over them before my car was totalled. Good luck
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Dec 24, 2000 | 07:41 PM
JPrevost's Avatar
Car: 91 Red Sled
Yeah, those AFR heads are great...except for the price. When it comes to hp:$ it's hard to justify when using nat. aspiration. Then again you're SCing and those AFR heads might just be the best hp:$ spent if you do everything else right.
I'm pissed that vortec heads don't have EGR. How hard do you think it would have been for them to make a version for all us NJ, NY, and CA peeps wanting cheap clean hp. :-( at least Chevy hasn't stopped making the 5.7 (ford went from 5.0 to 4.6, what a crock).
, Jon (91 RS too many mods to list), getting new engine in summer
Old Dec 25, 2000 | 08:12 PM
GlenYappa's Avatar
Thanks for the replies. I got a response from AFR about their heads and they said the intake is a little larger than a stock head. They claimed as long as the SC manifold is the same size or smaller I'll be fine. The SC manifold is made to replace the stock manifold so I think the AFR heads will have a slightly larger intake port. I think I could get away with just bolting everything together but it will be best to port match the SC manifold to the AFR head. To tell the nightmare I have had with Weiand's tech support I would have to create a whole new thread.
Thanks again for the responses.
Glen Smith
Magman
Sep 12, 2015 10:43 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
