302 Chevy in a third gen
Old Oct 1, 2009 | 10:28 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
I was wondering if anyone has done a 302 chevy swap into a third gen? I know that these small engines can make a lot of power up top. Pulling to 7500 rpm with easy. Would it be a fun car to drive on the street also? What Gears (4.10s, 4.11s) What kind of stall converter would be needed for a auto, or would changing it over to a 4 speed be better?
Old Oct 1, 2009 | 11:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 302 Chevy in a third gen
It would be slow on the street. Street driving is usually well below 5000 rpm. The amount of power you make with a 350 at low rpm will be greater than what you can do with a 302 at the same rpm.
A 302 will be better than a 305 but not as good as a 350+. Torque is what you feel on the street. The longer stroke of the 350 will make more low end torque for street driving than a 302 will.
The GM 302 was designed for CanAm racing. Road course racing with a 305 CID limit.
Old Oct 2, 2009 | 12:45 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
But the 302 came with 290hp, and 290 pounds of torque. It was underrated from what i've read. Those numbers are much higher than alot of 350s. With a proper build, with stiff rear gears, and a lockup converter 3500 stall, wouldn't it be a fun car to drive? When i cruise in my 305 on sundays it rarely sees third gear, it runs at 2500 in second at 50k with 3.23s so, with 4.10s shouldn't the car be above 3000 and isn't that where a 302 comes alive and pulls through to 7300 to 7800 depending on your Valve terrian. I don't know of anyone putting a 302 in a third gen thought it be cool.
Old Oct 2, 2009 | 01:19 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Agreed.
We drive Tq, not hp - we don't have autobahns or anywhere else to use top end hp.
302 is a great motor - identical in dimension (bore and stroke) as the Ford offering; we all know how well they make power. Then again if you want to go fast, a 350, 400, or even larger is the best way to maximize power under the curve. 15% more displacement equals 15% more TQ. 406 > 383 > 350 > 327> 302.
Old Oct 2, 2009 | 02:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That was also the pre-'72 rating method, when the factory used gross flywheel HP, headers, no accessories, velocity stacks on the carb, different intake to produce HP and torque ratings, etc., etc., etc. The '72-up net flywheel rating method drops that down significantly. And, neither reflects "real world" driving manners.
It would be a "purpose-built" vehicle - okay on the track, a hassle to drive on the street.
Want high-winding horse power, good-manners, good-fuel economy in a small block Chevy? Get an LS1. Guess what - it's a small-bore, long-stroke design.
Old Oct 2, 2009 | 02:29 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Seems to me a 302 would just be an expensive way to get less torque and some horsepower you won't use on the street. Torque is what makes street driving fun, either save some money and get more torque buildling a 350 or spend it up on a 383 or 400.
Also, just because a 302 made 290 pounds of peak torque doesn't mean it's providing the same torque, a 350 making 290 pounds at (x) rpm will generally have a much broader and more flat torque curve than a 302 making the same peak with the 350 doing it on a much milder build.
Old Oct 2, 2009 | 02:32 PM
five7kid's Avatar
Apples & oranges. The Ford also has 4 head bolts per cylinder, which frees up room for ports. It also leads to head gasket failures.
Old Oct 2, 2009 | 02:34 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
The 302 has a 4" bore and a 3" stroke came with a single plane intake, it was designed to make high end horse power at 5k-7k rpms. Designed specifically for racing where you are constantly in the throttle and in its power band. The 302 also came with solid lifter valve train to be able to rev that kind of rpm. Requiring specific adjustment and interim checks to ensure valve lash is proper. Unlike the hydraulic lifters that you set and don't really have to worry about.
The 305 has a 3.73 bore and 3.48" stroke, designed to make power lower in the powerband to keep engine rpm's lower consuming less fuel. Better driveability at lower RPM's where the car is 95% of the time.
Longer stroke = more torque and lower end power.
The 302 will bolt in and it will drive, probably be a unique swap also. I'd bet it will probably feel pretty gutless under 3500-4k rpms. You would definitely have to put a taller rear gear like a 4.11 for it to be tolerable on the street, or you would have to do 120mph everywhere to be in the power band. You will have poor fuel economy, due to having increased RPM's also. I would definitely want a manual behind a 302, I'd be willing to bet that with an auto a high stall, like 4k would be needed to get the car to move out with any kind of urgency.
Old Oct 2, 2009 | 06:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You could always put in the 302 then paint the car to look like an old CanAm or road race ca. Something before the IROC or Players Challenge cars.
Old Oct 2, 2009 | 07:26 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
I would say that practicality should be a consideration, too. Just how often on the street are you going to be able to zing that 302 in the 3500 to 7500 rpm range where it actually makes power??? Also, with a five speed and a heavy car, it might work on the street, but if your car is an automatci you would need a high stall converter in the 3000 to 3500 range---and they build a lot of heat...which further translates to trannies going south before they should!!!
Torque IMO is far more desireable in a street engine, something that builds 400 ft. lbs. of torque and 5200 rpm is a lot better street engine then one that makes 400 horsepower at 7500 rpm!!!!!
Old Oct 2, 2009 | 07:56 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
You all make very great points, basically i want something with power, that isn't a 350, 383, or ls1. Thoose are the three main motors that are dumped into a third gen, and make lots of power. But i would like to be a little different and have something different. So from what everyone has been saying build a motor that is gunna make alot of torque so a 400 small block would probelley be my best bet, then 327, then a 302 correct? I am not concerned at All about gas milegage what so ever as long as it can hit 140 to 150mph and accerlate fast i'm okay with it.
Old Oct 2, 2009 | 08:07 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
...Why not a 454?
Old Oct 2, 2009 | 08:11 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
Because i was told by a auto shop that i would need stiffer front supsension to handle the extra weight of the big block and i want to keep my 700r4 tranny. And i don't want to cut my frame.
Old Oct 2, 2009 | 08:23 PM
Parasoth's Avatar
Engine: LS1 / 455
you think a 300hp 302 that screams to 7500 rpm would be handled by a 700r4? aluminum heads and intake bring the weight down by about 100 pounds.. which is the same as your iron headed 305.. Where do you have to cut the frame?
Old Oct 2, 2009 | 08:26 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Then a 302 or 327 would be fine.
Old Oct 2, 2009 | 08:28 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
you have to grind and cut the frame to get the one header in and to get the hei in you need to dent the firewall, if i had a 302 a 4 or 6 speed would go it after i blew up my second 700r4
Old Oct 2, 2009 | 08:35 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
ever body is kinda talking me out of a 302 even tho with 4.10s i believe in the city the car would be right in the power band because 2nd with my 3.23s is at 2600ish. but i'm young and want to learn. As for the comment of gm dyno at 290/290 being lower because of the gross rating gm pulled the stock motors to only 5,400 when they could be pulled to 6,500 and make power so they probelly did make 290. Why is the 302 ford motor powerful and fun on the street?
Old Oct 2, 2009 | 08:38 PM
Parasoth's Avatar
Engine: LS1 / 455
You need to do more research my friend. So... you ARE planning to get another tranny... which means it doesn't matter if you bolt the 700r4 to a 454 and blow it up.... Why not use the patriot method, cut the flange, maybe weld some extra pipe to it to create the downpipe around the frame or beside the tranny...
Old Oct 2, 2009 | 08:44 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
i don't want to cut and weld when a small block isn't going to give me that problem and i just called the shop that will be assiting me in my build and even with aluminum heads its front end is going to need supension help.
Old Oct 2, 2009 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There's a reason those engines are commonly used. They do make a lot of power with little effort and cost the same amount to build as a smaller engine. You get more bang for the buck.
A BBC is about 150 pounds heavier than a similar SBC. Install aluminum heads and intake and it gets very close to the weight of a factory iron head SBC. Both my aluminum BBC heads weigh less than one iron BBC head. The nice thing about a BBC is that it makes a lot of torque at low RPMs where you'll feel it the most. I ran V6 front spring in my car for a number of years with no problems.
Frame modification for the header may or may not be required. It it does need to be modified, it's not as hard as it sounds. A large cap HEI distributor and a BBC fit in front of the firewall just like a SBC. The position of the tranny bellhousing doesn't change so the position of the distributor doesn't change.
Don't get all hung up on a 700R4. It's not the best choice for a transmission when using an engine with a lot of power. A TH400 is a better choice. If you feel you need an OD, a 200-4R is a better choice and if you're willing to do a lot of modifications plus the cost to do the swap, a 4L80E is a beefy tranny that will be hard to hurt. It just adds a whole lot more weight.
Old Oct 2, 2009 | 08:47 PM
Parasoth's Avatar
Engine: LS1 / 455
I trust this site more than your shop. I am done.
Old Oct 2, 2009 | 09:01 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
"I trust this site more than your shop. I am done. "
okay thats your own opinion i've seen this shop build countless hi-performance cars and they know their stuff. Motion Performance probelley the most recognizable shop for performance in manitoba
As for the 700r4 i do realise it isn't the greatest when it comes to holding up under power i thought i read somewhere that they'll hold up too about 500hp. The big block idea is cool, but id rather use a small block. Can 302 chevy run as good as the ford 302. If i was to change tranny s it be to a stick. Tx
Old Oct 2, 2009 | 09:52 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I think it would be cool, but if you're only interested in being different you could always build a strong 383 and tell everyone it's a 302 and nobody would be the wiser.
Old Oct 2, 2009 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Unless they see an externally balanced harmonic dampener. I can tell people that my 540 is a 396 or a 427 and they wouldn't know the difference because my engine is internally balanced.
If you want to use the performance shop's advice then you shouldn't be asking questions on TGO and just pay them to build what they think is best. Members here are very knowledgeable as to what works and what doesn't and why. We'll usually give the best advice and steer you clear of making bad decisions.
Stop comparing a Ford engine to a Chev. Each brand of engine has it's advantages and disadvantages. If you want to be different, just drop a Ford engine into your Camaro.
You're not going to be able to easily build a 302 anyway unless you buy a bunch of new aftermarket parts. The Chev 302 used the 4" bore 010 block that's been used in the 302, 327 and 350 engines. The 302 used the 327 engine at the time but used the shorter stroke of the 283. The difference was the crank. It used the 327's large rod journals instead of the 283's smaller journals. It's unlikely you'll find such a short stroke, large journal crank to make a 302. Since you'll need to buy many new parts, why limit yourself to a 302 when the same price can build a 350 or 383 and maybe a 406 or 434.
Old Oct 3, 2009 | 01:46 AM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
Because everyone has a 350 or 383 in there third gen. its boring, we all know that you can make good fun horsepower in those motors, every single person you talk to that has a 305, its ohh i'm gunna eventually put a 350, or 383 in it. i thought this site was meant to help people with their ideas. And reach their goals, i've watched 302 s on youtube and they haul so instead of telling me put a 350 in it which i don't want to hear does anyone know of a 302 build that will make it a fun car to drive, all this car is going to see is sunday cruise nights and the strip.
ps. if i wanted a 350 i would have put one in three years ago when i brought the car.
thx
Old Oct 3, 2009 | 02:26 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you really want to build a 302, the most budget friendly way would be to use a stock crank, rods, and block, and build a small journal 302. You can still inexpensively buy 327 blocks, and 283 cranks aren't very hard to find, most of which are forged. Maybe just buy a 283 and a 327, and use parts from both.
Old Oct 3, 2009 | 02:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Fun on the street, and unique? Put a big block in. Enough torque to pull your house out of the ground, sounds awesome, and its pretty rare to see a street-driven 3rdgen with a BBC in it. The cost of the swap is really not that bad either.. the bulk of the cost is just the headers and exhaust. I'm in the midst of collecting the parts to put a BBC in my Camaro right now. It will be just a nice driveable street car - maybe 400hp or so, with a set of 781 large-oval heads. The added weight isnt that bad, the stock V8 suspension will be fine. Subframe connectors would be a good idea though, to handle the extra torque.
Old Oct 3, 2009 | 04:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
We are helping you make the right decisions but you're not listening. With the thousands of TGO members, you'll get better advice than what the automotive shop wants you to do. Do you need to upgrade the front suspension with a BBC? No. Is it good to upgrade the front suspension? Yes.
Quite a few people come here with ideas on what they would like to do but have no clue as to what to do, what's involved or what the final result will be. You can put any engine/transmission/differential into any vehicle just to be different but that doesn't mean it's the right choice. It's sort of a catch 22 issue. If you have to ask about doing something different then you're not really sure if it should be done or not. If you're not willing to listen to the advice given, the question shouldn't have been asked and you just need to go ahead and do whatever you plan in the first place.
The final choice is up to you. Once you spend the money to drop in a Chev 302 into your third gen, you have to live with it, good or bad. Plenty of 350 or 383's will out perform you for the same price and they don't really care that you decided to build a smaller engine instead.
Old Oct 3, 2009 | 04:33 PM
bbccamaro's Avatar
Doesn't make much sense to me to try and run 140 mph with 4.10 gears?
Old Oct 3, 2009 | 05:15 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
That's not too hard with overdrive or tall tires.
Old Oct 3, 2009 | 10:01 PM
stroker_SS's Avatar
Engine: 355
How bout a BOOSTED 302, a nice twin-turbo setup,fuel injection, the works ya know. You'll have your 302 AND still kick some 383 or LS1 butt.
Talk about having your cake and eating it too.
Old Oct 3, 2009 | 10:44 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Just a thought,
How about a Bill Mitchell street small block, 427 cubes, 495 HP, 475 TQ, 9.5 compression, and a 2 year warranty to boot.
Old Oct 4, 2009 | 10:29 PM
Pocket's Avatar
Car: 91 Trans Am
The summary of this thread is you want a 302 to be different and more common (and practical) swaps like 350, 383(not really a swap), and ls1
Why?
Noone will know its a 302 except you. A SBC looks like a SBC no matter the displacement just like Stephen said
Next, you glorify that shop. Why bother asking TGO about a 302 swap when you wont listen to any of the responses?
Old Oct 4, 2009 | 11:08 PM
five7kid's Avatar
"I want to be different."
Translation: "I want to spend more money to be slower."
My applicable experiences:
1) 305 on steroids in the Camaro. Ran it from 2001 to 2005. It ran well, sounded good. In that time, I had exactly one person ask if it was a 350. Oh, he was a Ford guy. (When I did put the 350 in, it picked up 1.4 seconds and 5 mph in the 1/4 mile.)
2) The 396 in the '57. With the hood open at the track, the two most common responses, when they see it's a big block: a) "Oh, it is a big block. I thought it ran pretty good for a small block." and b) "It's just a 396? Why aren't you running something bigger?"
Old Oct 17, 2010 | 07:04 AM
johnnycarmaro's Avatar
i was actually considering this feet since i got some 302 parts from a 69 z that my dad lost to the po po in the seventies, he swaped engines before this happend, but to point out that originally the z car was the only 302 package in the sixties, meant for corner carving, and its quick acceleration, larger valves than 283 but shorter stroke than 327, and more hp than the 289 ford, was mistaken as an air raid sired during dyno testing, and the t/a 302 with double 4 barrals was rated at 400hp at 6500rpm and with the IROC-Z suspension and tighter steering ratio than the sixties camaros its almost destined to be in that car, it should have been made that way, 302's were also in seventies indy cars with fuel injection, during the sixties they didnt have ovrdrive or torq converter lockup, now we do, all i wanna know is what are the rpm limits on 305 fuel inj since i was only probably gonna get bigger injcters throttle body, maf, and a stronger fuel pump and a s10 converter with lockup, and either 4.10 or a overdrive unit on the back of the tran for lower lows and higher high gears, how many rpm can the 86 305 fuel injection do, hopfully 8,000. one more thing to point out, in the eighties fuel injection was amazing, doesnt anyone remember, the tpi fuel system is almost like the hemi, or the six pack, the cold air induction hood, vvt, dohc and so fourth, it was historical, when people switch to a carb its like taking away the whole point of why they were so important. no cold starts, or killin it when the engine back fires, cleaning the plugs all the time, and all the other bothers of carbs
Last edited by johnnycarmaro; Oct 17, 2010 at 07:24 AM. Reason: not clearly explaind as to what im asking
Old Oct 17, 2010 | 07:05 AM
just put in a higher stall when the engine produces more torq
Old Oct 17, 2010 | 08:24 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Always an amusing topic lol. Theres no way to make up for the torque loss and throwing a high stall at it wont make things any better. Heck, a stalled 350 sorta slugs around in town, so an engine with less torque would be sluggish at best. As mentioned, you can tell people it's a 302, 327, heck say it's a 235 and most people will take your word for it. When I had the LTR TPI people would mistake the TPI system for a supercharger and I'd go along with it. Most people will believe anything you say about your car, so tell them its a 302 and when you get beat you have a bit of an excuse, "it's just a 302".
Old Oct 17, 2010 | 02:38 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
if your car was a 82-85 5 speed ho 305 you could make a pretty deadly combo in a third gen i think strong rear gears be just like an old z28 with an extra gear.
Old Oct 17, 2010 | 02:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
More cubes=more power=more drivability with less cam and supporting top end. Just swap a 350 if you want power. If you want a 302 just to have one? Do it, dont let anyone stop you. With the right combo, a 302 will work fine, but you will exchange low end TQ for top end HP or the other way around, if you have a larger stall, it will help with deep gears, but fuel economy should not be something of a concern.
Old Oct 17, 2010 | 03:26 PM
maverick22's Avatar
Car: 1989 Camaro RS
Engine: 2.8
Transmission: A4
Maybe a 572 would be a better choice, annihilate the pony boys back home eh?
Old Oct 17, 2010 | 03:32 PM
maverick22's Avatar
Car: 1989 Camaro RS
Engine: 2.8
Transmission: A4
Throwing twin turbos into almost anything will make 1000 horses, and with all the money you've thrown at a twin turbo setup you may have well just bought a N/A 14k BBC with warranty and not have to worry about any of the problems associated with turbo setups.
Old Oct 18, 2010 | 12:01 PM
  #42
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
I had a 302 in my car... got it from a old timer that was getting a divorce he has it rebuilt buy spe racing engines out of spokane. it was close to 13.1 compression. heads were built, bottom end was forged and balanced he was building it for his open track 67 camaro... it had the offenhouser dual carb set up. i sold that and just ran a edelbrock victor jr with a 650dp. it was a awesome car above 4000k but in town sucked.. and no matter what u need higher octane gas.. and i was running the t5- little scared.. it took out my 373 10 bo
Old Sep 6, 2022 | 10:20 PM
  #43
Tomgillpie51's Avatar
hello I happen to have a 3rd gen with a 302 sbc. Its nasty I have the 302 built making 11.1 compression, somewhere around 500 hp dont take my word i still have yet to dyno it. i have the t51 5, speed going to a 4.56 rear. You better know how to drive it or it will simply drive you. I ran it the other day and launched as i would on the drag strip and I could not catch traction until i hit fourth. I know for most drag racing applications spinning is no good i understand that. Im still building at the moment, in the process of finding the right rear diff housing and everything to go along. It is definitely an exilerating ride.
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
BADNBLK
Nov 16, 2016 09:12 AM
Reborn756
Sep 4, 2015 03:42 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
