Goodwrench replacement 350
Old Jan 7, 2001 | 02:37 PM
89digger's Avatar
Hey guys, this is my first post. I saw an ad for Jim Pace parts, and I saw a neat engin. It is a replacement 350 for a 91-93 B-body. It has a 9.6 to 1 compression, roller cam, and Lt-4 rods. A pretty good deal at $1490. I'm planning to order this motor this summer, and changing the cam. I figure this should give me around 250 hp. It won't win many races, but it's a start. What do you guys think.
89 Iroc --Previous owner changed factory 350 with a 1984 305????
Old Jan 7, 2001 | 04:57 PM
rsilver's Avatar
For the money its a very good choice. I Assume you have TPI so I am not sure about the fine points of that swap, but I know many have done it with TBI and been pleased. I have heard you can expect around 250 Hp with a manifold and headers. The negative is that the LO5 heads are restrictive swirl port and probably the biggest limitation on that engine. I have heard that a cam is a big improvement
given the head limitations. It seems to be the easiest most trouble free swap and a great price. Check out the archives cause there has been a lot written about this swap
especailly for the TBI guys. If you have TPI you may want to ask how the engine works with that set up. Good luck.......bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
BBSDesigns
Aug 11, 2015 07:39 PM
