305-350
305-350
I'm just curious what I would have to do to drop a 350 in my cammy.. Right now it's a 305.. Am I going to have to change things like the axels and the tranny?? Someone said this to me before but I don't think I have to.. Someone enlighten me on this information.
Hey feel free to chat with me on AOL IM if you wanna.. Darkhal2000!
My site, <A HREF="http://www.demoncamaro.net
should" TARGET=_blank>www.demoncamaro.net
should</A> be up shortly.
Transmission: 4L80E/4L80E
Well, since your site isn't up yet, and you didn't give details about your 305 (year, induction, tranny, etc.), it's a bit hard to answer your question with specifics.
Generally, though, the 350 will bolt in place with your current induction, exhaust, and accessories. If it has a knock sensor, a 350-type sensor and module should be installed (although not absolutely necessary). A 350 harmonic balancer should be used. The heads will have to be the same for your intake to mount (in other words, '86-newer or '87-later; new has to be the same as the current). And, depending upon your current engine and what you get for a 350, you need a flex plate/flywheel that is made for the type of rear main seal it has (one- or two-piece).
The axles and tranny will be fine, although a 5-speed might be a bit weak for all-out thrashing by a torque-happy 350.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
ok cool so I'm all set to drop the 350 in.. sorry for the lack of info
My site, demoncamaro.net (add the WWW but this thing messes it up) Should be up soon.
rockfourone
Dec 15, 2008 03:51 PM
smallblockking
Jan 29, 2008 09:11 PM
smallblockking
Nov 9, 2007 05:02 PM
86White_T/A305
Nov 19, 2006 09:17 PM
