V6EFI to V8carb question
Old Jan 13, 2001 | 08:42 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i have a V6 in my bird, and i am putting a mild carbed V8 in it. my question is this, will the factory gauges work? i know the tach wont, but what about the oil, temp, voltage gauges? i am assuming i will completely unhook the computer, i am not for sure all of the things i will have to do untill i start the project. also, i am wanting to use the stock electric in-tank fuel pump, i know i will need a return line and a fuel regulator to run this setup with a carb. thanks for any help. lil j
Wide Open Till You See God...Then Brake
Old Jan 13, 2001 | 11:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those others should work correctly, as long as you get the right sending units. You can swap the tach with a V8 one and that will be right too.
Old Jan 21, 2001 | 10:52 PM
MILT's Avatar
Voltage will work, Oil will work, Temp will work. Throw a MSD box in there to run the tach as long as you're doing the swap. Also, use a Mallory 3+ adjustable fuel pressure regulator. It will allow you to use your stock MPFI pump.
feel free to email me any questions, as I have done this swap a couple of times...
MILT
'83 HOmaro--doesn't run
'92 Bird--burnt to a crisp
'78 T/A 400--fast, Burt Reynold's style
'83 Buick LeSabre--the Ghetto Cruiser
"Without evil there can be no good, so it must be good to be evil some time!"
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
