The BBC is in!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The BBC is in!
Finally! It's been a long weekend and most of it was spent getting the headers on.
The engine is in. It runs. The cam has been broke in and the car moves.
Still needs to be done:
Install inner valve springs. Going to be real fun getting the back 2 spark plugs out on the drivers side to insert an air line. I installed the plugs from under the car. There's less access than the BBC in my truck. I suppose if the brake booster was off there would be more room. Hmmm. Next thing on my list of things to do.
The carb isn't adjusted yet. It idles at 1200 and the mixture screws haven't been touched since the carb was on the 383.
I need to install some collector tailpipes so that I can install crankcase vents in them.
As nice as it is having a BBC in a third gen, I wouldn't recommend the swap to anyone who hasn't done anything like this before. This isn't an easy swap and there's a lot of stuff removed from my engine compartment. The biggest headache is the headers. Plan on a full weekend to get them in if you don't have access to good shop tools. I'm lucky and have access to a plasma cutter, mig welder and torches at work. Having the car up on a hoist would make the jog go easier also. I only had jack stands. I think from the time I pushed the car into the shop to when I drove it out, the installation took about 18 hours. At least 9 of those was getting the headers in
Well it's in. Now I need to get the rest of the car ready for the start of the race season in 3 months. The time will get here quickly if I don't do anything.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
AWESOME.....your car rocks.
Mine's almost done. I spent this weekend stuffing the 454 in and hooking up the majority of things. This week I will be picking up a few odds and ends and making a few brackets. The acid test will be next Sat. when I fire it up.
you can check my car out under "BSR Members" at www.bsronline.net/
85 Berlinetta Iroc exterior Lg4 305 best e.t 14.4 street tires naturally aspirated....installing/ rebuilding 450-475 HP 454....YAHOOO!!!
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
CONGRATS! Is this Camaro a daily driver or strictly racing?
Big 454 '86 Camaro Z28 '72 Nova w/454 BBC
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Good to hear...in no time you'll be doing this:
<center>
</center>
This back-halved 84 Z has a 509 and has run a 9.1 second quarter as of late last year....the new owner is still getting the hang of it.
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
<center>
</center>This back-halved 84 Z has a 509 and has run a 9.1 second quarter as of late last year....the new owner is still getting the hang of it.
Pete
Pete's Place
HiOutput Tech Page
83 SC
14.935@94.14
Stephen,
Are the motor mount brackets which bolt to the side of the block the same on a big block
and a small block? Do you use the short or
the tall ones? I have seen this asked on several message boards, and everybody has
different responses.
Car: 87 IROC L98
Hey that almost looks like my car except I don't have headlights and mine isn't tubbed. Maybe in a few years I'll back half the car. After dropping in the big block, that tubular front crossmember sure looks like a good idea also.
As my web page says "No it's not street legal" It would be cheaper to buy another car than to make this one street legal again. It's going to end it's life as a race car.
9.1 with a 509. Any nitrous? If not then that's pretty good for just the engine. I'm guessing about 800hp to run low 9's depending on the weight of the car.
Motor mounts. I originally had the GM clam shell mounts. I don't know what year the mounts were from. I think they were truck mounts. I used Moroso solid mounts upper and lower for third gens. They work will all big and small blocks.
Moroso #62510 is the upper mount
Moroso #62610 is the lower mount
[This message has been edited by Stephen 87 IROC (edited January 29, 2001).]
Nordbert...I'm firing up my 454 tomorrow night for the first time. Unlike Stephen's car, mine WILL be street driven. As for motor mounts, I just used the ones from my 305. Still has the heater and everything. P/s isn't hooked up yet, but I don't need it to break the engine in. I think I saved myself some major headaches by not using headers. I would have loved to have used the Hookers, but the cost after the engine, radiator and hood, was a little to pricey for me right now. I'm just using truck manifolds that have been treated to a thorough port job. I don't want to spend anymore money until I know this thing is going to run properly, know what I mean?
[This message has been edited by CrazyRob75 (edited January 29, 2001).]
Car: 87 IROC L98
Hey don't laugh. After many hours of fighting and fabricating, I was almost finished installing the headers when I was starting to think that cast iron manifolds would have been a better choice!
For a street driven car it probably would be a better, easier and cheaper choice. The Hooker headers are nice but have patience and time to get them installed.
Crazy: After reading your sig I guess I can say my engine is an estimated 530-550 HP. I already had a 450+hp 383 and it wasn't enough.
I;ll be checking your page out. Hopefully you put some pics of the headers so I know what I'm in for in the future. The biggest reason I didn't put hookers on was the fact that I did this at home with no air tools or any type of welding set-up. I work at a Ford dealership, and they kinda get sick of seeing my "POS" in there all the time. I'm going to take it down my backlane to Minute Muffler to get them to weld the manifolds to my y-pipe. My work is about a 15 min drive away, so considering it has an open exhaust, no hood, is uninsured (parked for the winter, I do have storage insurance), and the roads are iced over, I don't think I want to take the risk.I know my exhaust is a MAJOR restriction right now, but once it's mobile, and as time and money allow, I'll slowly start improving things.
Boy are my neighbours going to love me tomorrow night! it's going to be loud!
redformula88
Oct 14, 2015 06:08 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
