305 block weight?
Old Feb 4, 2001 | 07:59 PM
Maverick13's Avatar
305 block weight?
Question: How much does a 305 block weigh?
Maverick
1989 Formula 305 TPI 5-speed
Suspension mods, stock engine
Old Feb 4, 2001 | 09:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
About the same as any other SBC block. Somewhere between 100 and 150 pounds would be a good guess. I've picked one up and carried it across the yard.
Old Feb 7, 2001 | 03:20 AM
JPrevost's Avatar
Car: 91 Red Sled
I'm not positive about this but from what I've read on the internet a heavy duty 350 iron block weighs 197lbs and an aluminum is only 90lbs. The lightest iron block was 180. You're one strong **** for walking a block with no help.
, Jon (91 RS too many mods to list), getting new engine in summer
Old Feb 7, 2001 | 03:45 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
I'm gonna go with J and say in the 180 range.
I know for a fact that a 1971 350 block from a suburban is Noticably heavier.
It's always SOMETHING
"Sounds like Barry White at idle, Teddy Pendegrass wide open..
if it don't sound like Micheal Bolton your alright"
Old Feb 12, 2001 | 12:53 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i'm gonna go with 180-190.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 12, 2001 | 01:36 AM
Guest
Guest
Posts: n/a
I couldnt take it anymore... Ive carried a block too, so...
I just weighed my std. bore 350 4-bolt roller block, its just the block; no crank, rods, pistons, cam, nada. Probably weighs slightly more than a 305 since it is a 4 bolt which means 6 more bolts and 3 larger main caps. And 305's are thinwall castings too.
157lbs.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
