How bout a "Camaro Conversion Kit" in a M5?
Old Feb 11, 2001 | 01:21 PM
Satan87Z28's Avatar
The kit is designed for a 82-87 LG4 with auto but what about swapping it in a car with a T-5. What all would I need to do to the T-5 to handle the power, or what else needs to be done in order for the car to run with the new motor correctly. The said one for the manual is said to be in the works but who knows how long that could take or if it would happen. A lot of you guys have LG4's w/T-5's and this kit sounds sweet.
Old Feb 12, 2001 | 09:37 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Hey, I think I can answer your questions. Not only did I use this kit on a manual car, I also swapped from a V6. So I probably ran into every little problem there is.
First, if you have a two-piece rear main seal block, you'll need a different flywheel.
Second, the transmission-to-dual-cats hangar is transmission specific. You can just order the correct one from GM, it's still in production.
Third, make certain you have a working VSS because the automatic PROM that comes with the kit will bitch if you don't.
That should be about it! All in all adapting it to a M5 car is pretty easy. Easier than an M5/A4 swap, in any case.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Old Feb 12, 2001 | 09:41 AM
99Hawk120's Avatar
Oh and as far as the T5 handling the power... I hope you have a world class T5. If not, you'll see where the T5 got its lousy reputation.
If you have a WC T5, like I do, you'll find that it does ok as long as you don't abuse the hell out of it. Drag racing on slicks with powershifting is a no-no, although the slicks will probably break your rear-end first if you have an earlier 10-bolt.
92projectcamaro
Sep 29, 2015 07:07 PM
bbsr72
Sep 27, 2015 05:55 AM
89bird2.8
Sep 18, 2015 07:46 PM
Jetmeck
Sep 4, 2015 12:29 AM
