Easiest crate engine to replace my slow 305?
Old Feb 9, 2001 | 01:35 AM
86w/slow305's Avatar
I have an 86 TA in excellent condition. the problem is that it lacks power and it has 112,000 miles on it. it now has a 305 4bb. I was wondering which crate engine would be easy to put in. Should I get rid of all the computer crap? Will I need to buy anthing exta? I'm looking for something that i can modify a little later. all i need now is a 350 that won't exceed $1,500. Thanks for any suggestions.
Old Feb 9, 2001 | 10:10 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
for 1500 bucks, you will have to stick with a "replacement" engine or "target motor", which will be from GM Goodwrench, not GM Performance Parts. these aren't really considered a crate engine as far as performance goes. you can pick them up for like 1200 bucks, check www.paceparts.com.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 12, 2001 | 05:28 PM
Mike92's Avatar
I would save up for a Vortec crate 350, yes it's more money. ($2000 or so) But it would make your car outrun new GT's 5-speed's and Auto.
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
marcusaw
Aug 10, 2015 08:13 AM
