T.P.I. into a non-injected car - Fuel Pump Questions
Old Feb 15, 2001 | 08:25 AM
Mrfixit's Avatar
I'm in the process of installing a 89 T.P.I 350 into a 68 RS Camaro. My question is about the fuel pump. My first thought was to buy an aftermarket electric pump but they all seem way too expensive (approx $300). I would also have to build a small reserve tank in the fuel line to prevent starvation on hard cornering not to mention trying to find a place to mount all this stuff.
Lately, I've been considering just modifing the existing tank to accept the 89 in-tank pump. To do this, I will need to cut the top of the tank and weld a fuel holding pan into place, again, to prevent fuel starvation during corning.
The third option I suppose would be to buy a fuel cell of some type. There again, the expense makes this less desirable.
I guess my question to this group is: what modification have you sucessfully completed to convert your non-injected car to fuel injection? Does converting the original tank seem feasible?
Thanks for the feedback (in advance),
Roy
Old Feb 15, 2001 | 01:56 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I could be wrong, but if you go with something like the T-Rex inline fuel pump you shouldn't need another area to hold fuel to prevent starvation in the corners.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 15, 2001 | 03:47 PM
Mrfixit's Avatar
Hummm... The T-Rex is still around $250. That may be an alternative but I've read a few comments and they all have said the pump is quiet when first installed but get noisy very quickly. I don't like the sound of that. Also, with out a reserve fuel supply, wouldn't it simply starve for fuel on hard corners like all the others? Any other ideas?
Roy
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
