TPI air intake for ls1 swap?
Old Oct 17, 2009 | 09:55 AM
Roachjr's Avatar
Ok so I have a 305 TBI right now, But Im doing the LS1 swap. Should I try to find a stock TPI air intake box like what comes on the 82-92 TPI's or should I just route a tube from the throttle body to the side and just put an air cleaner on the end? wasn't sure if the stock TPI air intake was very restrictive or not..
Old Oct 17, 2009 | 10:23 AM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: TPI air intake for ls1 swap?
the stock TPI air intake is pretty restrictive for the ls1 from what i've read. everyone that does these swaps make there own cold air intakes. And intake for a 04-06 gto will work well for you.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
