ZZ4 swap- cooling question
Old Oct 17, 2009 | 12:09 PM
crewguy's Avatar
1986 Camaro...
I have built a ZZ4 (10243880) and now I am wondering about cooling. Does this motor require a reverse-rotation w/p to adequately cool the motor? If so, what is the cheapest route to run a serpentine belt system? I am not using an A/C, only power steering and alternator.
Old Oct 17, 2009 | 12:16 PM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
Re: ZZ4 swap- cooling question
you are pretty much running the same setup as i am. here is a picture not sure on the water pump rotation though. but i am running the serpentine setup. The serpentine setup is not that much being that you only have the alt. and power steering pump. I actually have my power steering running on a V-belt over the water pump and the crank and the alt. running the serpentine belt on the water pump and crank.
Old Oct 18, 2009 | 03:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The rotation direction of the water pump depends only upon the type of accessory drive system you have, not the engine you have.
Stock from '82 to '87 ran the water pump the same direction as the engine. '88-'92 used a serpentine system, which runs the water pump opposite of the rotation direction of the engine.
So, what do you have?
lt500r55
Sep 1, 2021 01:30 PM
chazman
Aug 28, 2018 03:25 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
