How does this build sound?
Old Oct 17, 2009 | 03:26 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Here's what I want to build for a guy with a 85Z. A 406 vortec hybrid motor. Basically, heres the parts:
Alum vortec heads, 200cc int,72cc exh 64cc combustion, 202/160 valves
comp cam 230/236 .49/.49 110 lsa
cast crank with 5.7 rods
static compression at 9.5 dynamic at 7.5
750 edelbrock carb with air gap intake
long tube headers into a y pipe
3 row aluminum radiator
I think this should be a good, solid combo, what do you think?
Old Oct 17, 2009 | 04:12 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: How does this build sound?
i think the pistons will need too much dish for a 9.5:1 comp ratio with 64cc heads. you might have a detonation problem. everything else sound like it will work well. you would need a 25cc dish at 0 deck clearance for 9.5:1
Old Oct 17, 2009 | 04:19 PM
dellman83Z's Avatar
The pistons I found are actually 30cc dished. What calculation are you using for compression ratio.It seems like wherever I go, I get a little bit different number every time.
Old Oct 17, 2009 | 04:28 PM
http://www.csgnetwork.com/compcalc.html thats a little too much dish for me. the flatter the piston top is the better quench you will have (less chance of detonation)
Jorlain
Oct 8, 2015 01:57 AM
Lanz06
Sep 14, 2015 07:16 PM
Blue419
Sep 10, 2015 01:03 PM
84 TA NV
Sep 6, 2015 08:02 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
