BBC headers, sanderson or hooker super comps?
which fit better? im gonna need to order a pair in about 2 weeks and im not sure which to go with...
the sanderson's are only $285 and theyre suppose to fit 70'-92' bbc camaros... 1-7/8" primaries, 3" collectors...
then theres hooker super comps... $365...
which is better, and more importantly which fits better?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
70-92? I doubt it unless they are a shorty style and even then I doubt it. The chassis is different and second gen headers won't work on third gen etc.
I just installed a set of Hookers on my car. It's not a direct fit, bolt on operation. Frame, crossmember, lower control arm mounts and floor modifications are required as well as having to lift the engine high to get them in.
I never heard of Sanderson headers but you get what you pay for.
The easiest to install would be a set of cast iron manifolds.
I just took a look at the Sandersonheaders web site. Their headers are nothing like Hookers. They look more between full length and shorties and designed more for street use. From how they look, the installation should be easier.
Hooker's are considered SuperComp headers. Although they can be used on the street, they are more designed for racing.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited February 04, 2001).]
Best 60 foot: 1.662
are you talking about the 3rdgen bbc swap hooker super comps? or are you using just a set of regular hooker's?
the headers are gonna be for street use... so is the car actually... not really a daily driver, just something to drive every now and then...
does anyone know if the 3rdgen bbc swap headers need a whole lot of modification to install?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I used the third gen swap hooker super comp headers and it took a lot of modifing to get them to fit correctly. (Info is on my page).
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
also look at nhra super stock headers. I use jack davis headers in my car and they fit like a glove (no cutting/welding or engine contortions). they are not cheap ($700) but you get what you pay for. the hookers are so small 1 7/8 x 3" collector, i wonder if they are worth the effort as opposed to a good factory manifold.
Dan
Dan
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
