LO3/LO5 Motor Swap?
Old Feb 26, 2001 | 04:37 PM
Spyder's Avatar
LO3/LO5 Motor Swap?
Okay here is a wild idea for you guys. My dad wrecked his 1991 Z-71. He just had the motor rebuilt on it. I was thinking that this would be a half what good idea. LO3/LO5? For those that don't know the LO5 was the 350 counter part to the LO3 (305). From what the guy at GM told me they are rated for 240hp. That maybe wrong and if so I would like to know the actual rating on it. It wouldn't be a hard swap from what I gather. Would I even need to swap any PROM or compter stuff? Does all the wiring hook right up? The truck is the the drive way I might as well get what I can from it, its free after all :-) I don't want a load of HP but 250-300 sounds good. I wanna keep it TBI for gas milage and keep it some what stock looking. I assume that my intake would work on it. The heads were just redone so they should be fine. Then with the 14X3, thermo/fan switch.... Might be a good combo with the T-56. Also does this have the 2" bores on the TBI? What do you guys think? Am I missing any possable problems? Let me know, the car is sitting there for the snow to go away and I wanna play with some thing :-) Thanks guys, we have a lot of smart people here and hopefully we can come up with some kick a$$ tbi to play with.
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats (and thats it), AC delete, alu drive shaft, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
Project car, ZZ4 in the works.
Old Feb 26, 2001 | 05:07 PM
JPrevost's Avatar
Car: 91 Red Sled
That is a very easy swap. I bet the L05 even has the knock sensor so it's nothing more than unplug and play.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
