502 rat motor
Old Feb 27, 2001 | 02:22 PM
FlaTToPP69's Avatar
502 rat motor
what would it take to install a 502 into a 92 rs while maintaining a manual trans p/s a/c and decent driveability?
Old Feb 27, 2001 | 05:12 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Money
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Feb 27, 2001 | 07:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Good to hear time isn't a factor...!
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Feb 27, 2001 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Time is nothing. It took me 4 months to build and install my big block. Most of that time was spent waiting for parts or machine work. $8000 later the engine is in and the car moves. Now if I wanted P/S, A/C and drivability, I'd probably still be working on it. The manual tranny would be a waste of time for an engine like that. Maybe if you bought a Lenco or a Jerico but again it comes back to money again.
Before deciding what you want to put in the car, decide how much are you willing to spend. Lots of money can do anything.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 28, 2001 | 12:17 AM
JPrevost's Avatar
Car: 91 Red Sled
New trans, T5 will break first day with that kind of torque and hp. Even a 454 with 200hp will rip the trans apart so figure LOTS of money and LOTS of time.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
Old Feb 28, 2001 | 05:39 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The rear end will chew itself up in short order too.
That sounds like beefed and girdled 8.5" 10 bolt or 12 bolt or 9" F?rd material!
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
