Engine options, barely streetable for 6 grand??
Old Feb 27, 2001 | 10:54 PM
Superblue87Formula's Avatar
I have about 6 grand to spend on a (turnkey) engine combo, I want to get the best 1/4 mile times possible and still be able to drive my car around on nice days.. My original plan was for a 355 w/ all forged bottom end to handle 250+ shot of nitrous, but people are suggesting I use a 383, I just want to go as fast as I can for the $$ help! I am putting money aside for a replacement trans and rear end just in case
I am also putting in new rear suspension and running 10" slicks. I would love to crack 11's but I probably don't have enough money
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Feb 27, 2001 | 11:01 PM
what about getting this motor with forged rods and pistons, and spraying about 100 - 150 shot on it?
http://www.enginefactory.com/c38.htm
oh yeah, I have an 87 350 block, heads, crank, and rods sitting in my garage (came out of my car, was for 355 project..) and a zz4 cam set with springs/locks/retainers and rocker arms..
[This message has been edited by Superblue87Formula (edited February 27, 2001).]
Old Feb 28, 2001 | 12:10 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
A 383 would be a sweet motor. I myself am about to install a 383 in my 86 Z28. My set up is as follows: 186 casting heads(worked on),flat top pistons, cam specs-224int.234 exh. .488lift,dual exhaust,750 holley v.s.,Edelbrock performer intake and 2500 stall converter. Compression should be around 10.2:1 . I can't wait to drive my Camaro.
Big 454 '86 Camaro Z28 '72 Nova w/454 BBC
Old Feb 28, 2001 | 12:58 AM
3.1 firebird's Avatar
the stock bottom end should be good for 400 hp if its in good shape. Why not get a supercharger, or get forged pistons and nitrous.
Old Feb 28, 2001 | 06:44 PM
BoostedThrills's Avatar
3.8 Turbo buick
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
