How much should I pay for used 2.8L engine?
Car: 2004 GTO
I am buying an '89 V6 Firebird is great shape for $100. The motor knocks badly, so I am going to put in a used junkyard motor and donate the old one to the local High School Shop class.
How much do used 2.8L V6 engines go for on average?
Car: 4
Engine: 6
Transmission: 5
As little as possible, maybe less
ICON Motorsports
ICON Motorsports
Car: 92 Formula
Transmission: A4
Well, a couple people have given them away.....
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
92 Rs 3.1/T-5
Clarion Head Unit,
AIM : Theonekiztope
ICQ: 8787542
Transmission: 4L80E/4L80E
Sounds like they're including the cost of a guarentee, which means they aren't going to risk giving you just any engine.
Try the Classifieds on this site, and also ask on the V6 board. You'll probably do better there (might even get an engine just for hauling it away - no joke).
AFAIK, there is no reason you couldn't use the basic engine from a front wheel drive car, so check your local paper's classified for those cars as well. I believe the S-10/S-15's had the oil filter in a different location, but a remote mount filter conversion would solve that problem and allow you to use engines from them as well.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 88 Firebird WS6
If you have a couple buddies go with you to the pull it yourself yard and score one out of a rear-ended front driver. The difference is the intake manifold (use your old one) and most were speed density not maf like you probably have. If you use all your ducting and wiring you don't need to swap the ecm. The yard in my area charges $80 for a motor if you pull it yourself no matter what size engine it is (my brother scored a 440 out of a new yorker to rebuild for his six-pack for $80!!!) Most 2.8 in camaros are usually there because they are tired. Smashed front drivers at least ran before they got there (not a guarantee though)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
