ded L03 come with a melonized ditributor gear?
Old Feb 28, 2001 | 01:00 AM
JPrevost's Avatar
Car: 91 Red Sled
Does the stock L03 305 TBI from 91 have a melonized distributor gear? Yes or No, if no please tell me if it is possible to just buy the part (melonized distributor gear P/N 10456413) and put it on the distrib. Where on the internet are directions to do that because me and my friend have never had to change the gear.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
Old Feb 28, 2001 | 01:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Factory roller lifter cam engine = melonized gear on the distributor.
Even though it doesn't apply, changing the gear is pretty simple. Remove distributor (after putting engine on #1 and marking location); put gear in wood v-block, use drift & hammer to drive out split pin; remove gear from distributor shaft, save shims; install new gear; check clearance b/t gear & housing, remove gear and add/remove shims if incorrect; reinstall distributor; recheck timing.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Feb 28, 2001 | 04:29 PM
JPrevost's Avatar
Car: 91 Red Sled
Thanks, the gear has 145K on it so I think I'm going to just do the change so I don't have to worry about it.
Old Feb 28, 2001 | 05:43 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
If your running a stock small cap distributer I have a spare distrib gear with about 500 miles on it (I upgraded to MSD and the gears are different) I'll give it to ya for shipping. It's made by Borg Warner and just started getting 'contact' shine.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
[This message has been edited by JoelOl75 (edited February 28, 2001).]
Old Feb 28, 2001 | 07:47 PM
JPrevost's Avatar
Car: 91 Red Sled
Joel, you have mail.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
