ENGINE IS OUT!!! Please HELP!!!!
Old Mar 3, 2001 | 03:46 PM
galaxie_ford's Avatar
I have the engine pulled out of my 87 GTA.
What would you guys suggest that I do to my car BEFORE I drop it back in???
I am having the engine COMPLETELY rebuilt, what else can you suggest I do to my motor for some extra performance, that will not cost me a fortune. I am already spending that!!! I dont want to go extreme like a stroker and such...
Thanks alot...time is of the essence...the engine gets dropped back in on thursday!!!
Old Mar 3, 2001 | 03:58 PM
ede's Avatar
ede
up grade the cam, pistons and port what ever you can. you should be replacing most of the parts any way. up grade the ignition parts as well. flow match the injecters.
ICON Motorsports
1st & 3rd
Old Mar 3, 2001 | 05:05 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
Spend some time cleaning the engine compartment. You'll be glad you did.
Old Mar 5, 2001 | 12:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You really should have asked this at least a month before you took the engine out. To do porting, for instance, you should figure a couple of weeks to get everything apart, cleaned, ported, and back together (unless you can work on it day and night - most of us can't). Most internal engine parts should be ordered before machining is started.
Cleaning up the engine compartment while the engine is out is good advice, though.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
