454 swap
Old Mar 5, 2001 | 08:42 PM
pronger44's Avatar
454 swap
I would like to know wht parts i would need to change to handle a 454
Old Mar 5, 2001 | 08:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
First of all do a search through the archive. There are lots of messages about doing the swap.
Swapping the parts depends on what you originally have and what you want to do with the car. Originally tranny's and diffs can break with a stock small block just as easily.
It's easier to build a 400-500 HP big block than it is with a small block. Even a 400 HP big block is a stronger engine than a similar small block because of all the extra torque.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 6, 2001 | 10:34 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It's on my page.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
