Flex From 5.7 in T-tops?
Old Mar 9, 2001 | 04:18 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
I plan on getting a Remanufactured motor and i was wondering if i should stay with another 305 or get a 350. Im kinda worried about Chassis Flex. so what should i do? Go with a 350 and get a pair of SFC's? But then what electronics and other Misc. crap do i gotta change over? Im having a shop do the work so i need some opinions.
Old Mar 9, 2001 | 08:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't get any flex in mine and it was an original 350TPI with T-tops. The car now has SFC and a 6 point roll bar to stiffen it up.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 10, 2001 | 06:41 AM
ausrs's Avatar
get the 350
Old Mar 11, 2001 | 08:17 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm putting a near 500hp 383 into my 305 T-Top IROC-Z. I'm getting SFC's and a STB to start....if I need more I'll get a cage.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old Mar 12, 2001 | 10:20 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
after i put my engine in, i started to get a little crack in teh paint neat the corner of the passenger side t-top. maybe a coincidence, maybe not. i am DEFINITELY getting the SFCs though.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Mar 12, 2001 | 01:21 PM
Mark W. Winning's Avatar
Get the SFC's. When my car was a V6 it cracked a T-Top.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Mar 12, 2001 | 03:18 PM
sunbound's Avatar
Car: 1987 IROC-Z
as far as changing electronincs, i didnt have to change anything. last sumer i took out a dead 305 and out in a 350.
when i tried the chip from the doner car, the engine wouldnt start.
sunbound
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
