305 TPI to 350 TPI
Old Feb 28, 2001 | 09:00 PM
camaro6spd's Avatar
305 TPI to 350 TPI
What is required in doing this swap. No much right? Does the harness and sensors have to be changed/added/modified?
-Thanks
-Tom
Old Mar 1, 2001 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
a) A 350 (also see below).
b) Depends on how much your defination of "much" is. To some, a 350 is "much".
c) No.
d) Knock sensor & module should be for a 350.
You should also have a 350 harmonic balancer. 19 lb 305 injectors can be used, but you should get an adjustable fuel pressure regulator (AFPR) so the pressure can be bumped up. 22lb 350 injectors could/should also be used and w/AFPR. Depending upon the year of your current engine vs. the 350, you may have to get a different flywheel (one-piece vs. two-piece rear main seal crank differences).
The plenum should be ported - doing so helps a 305, so definately should be done for a 350. Exhaust help (headers, y-pipe, hi-flow cat, cat-back) also does a 305 good, so do it for a 350 for sure.
Scared off yet? Good, get the catalogs and plastic out, and get that baby going!
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 5, 2001 | 07:02 PM
camaro6spd's Avatar
Thanks, I think you have given the best answer to this question that i have ever seen.
Old Mar 5, 2001 | 10:42 PM
illegal87's Avatar
Is not the 350 chip also needed?
Old Mar 12, 2001 | 03:28 PM
sunbound's Avatar
Car: 1987 IROC-Z
the stock chip should work. worked in my car. the original angine was a 305, now a 350.
sunbound
[This message has been edited by sunbound (edited March 12, 2001).]
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
