305->350 upgrade=less power?!?
Old Mar 1, 2001 | 11:52 PM
kevin-design's Avatar
After much excitement and anticipation, I got my camaro back today having had the 305 removed and a freshly rebuilt 350 (.040 over) installed- only to discover LESS power to the wheels. I'm not sure what the problem is, but I think I can say that I definately have less power now then when I had the 305 (b4 it blew up). In addition, it stalled at low idle today in a parking lot. Something is definately out of tune.
My theories:
#1- I know they kept the 305 induction, this produces a '91 350 engine with a TBI system off my original 305. From what I can tell, there never was a combination of 350/TBI for those years, they were all TPI.
#2- Despite running fairly smoothly (at least it sounds smooth), the computer or chip remains that of the original 305 as well, Can someone confirm if all the electronic controls were compatable?
#3- The cam or other timing parts such as a distributor, may not match up.
this engine has remanufactured heads, timing chain, block, new pistons, rings, water pump, thermostat, etc., etc., etc. I p;an to update the Eprom when I get the chance. Any ideas on what's holding back the power in my 350? Thanks for any help! Especially things to look out for (or test)! I was going to get SFC's to deal with the added torque and power, but if this is all I get then forget it! Thanks again!
-Kevin
Old Mar 2, 2001 | 12:14 PM
Mike92's Avatar
Post this on the TBI board and you will get more responses. The comp thinks you have a stock 305 in their, get a chip
Old Mar 12, 2001 | 03:34 PM
sunbound's Avatar
Car: 1987 IROC-Z
my 87 has the stock 305 chip in it, and it's got a 89 350 in it now. it's never stalled on me. i tried the chip from the 89 and it wouldnt start. and then again, the 89 had an automatic in it, and the 87 still has the stock t-5.
sunbound
Old Mar 12, 2001 | 08:08 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
What I would do if i was in your situation is I would put in a carburator and eliminate the computer. Eliminating the computer is easy as 1-2-3.
Big 454 72 Chevy Nova
383 86 Camaro Z28
[This message has been edited by Big454blockchevy (edited March 12, 2001).]
Old Mar 12, 2001 | 11:36 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Well... maybe...
1. - New manifold
2. - Carburetor
3. - Fuel Pressure Regulator to lower the tbi's 6-9 (?)PSI so it would be suitable for a carb.
4. - A non-computer controlled distributor.. on the stock one the advance is controlled by the ecm, by eliminating the computere and keeping the old distributor you will have no advance which will make the car run like S**T
other than that, it should be pretty straight foreward
Old Mar 13, 2001 | 02:01 AM
Car: 86 z28
Ok it's easy as 1-2-3- and 4.
383 86 Camaro Z28
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
