advice on removing engine while still turnkey
Old Oct 28, 2009 | 07:21 PM
aablack911's Avatar
Car: 89 Iroc-Z/well in theory
Engine: 5.7 350 TPI
Could anyone tell me at the very least what i have to disconnect to remove my engine. Any links or manuals...anything helps thanks.
Old Oct 28, 2009 | 07:30 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: advice on removing engine while still turnkey
unplug all of your sensor. unbolt the engine ground straps. remove radiator. power steering pump remove the return and pressure lines, if re-using unbolt it from bracket and move aside. undo tranny cooler lines from radiator. remove through bolts in the motor mount.
those are just things attached. i may be missing some.
Old Oct 28, 2009 | 07:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
transmission - unless you are pulling it too, then disconnect the tranny crossmember and torque arm mount, remove driveshaft pinion bolts and remove driveshaft, and shove a Tylenol bottle in the tailshaft to keep all the tranny fluid from leaking out.
Old Oct 28, 2009 | 09:05 PM
z28frost91's Avatar
Car: 91 Z-28
Engine: fresh 355 carb'd
Transmission: 700-R4
I pulled the 350 TPI out of my 91 Z28 with the tranny attached by just unplugging all the wires and ground straps, radiator, tranny lines, unhook fuel lines and powersteering lines, disconnect driveshaft. even left the crossmember on the chassis. undo VSS and TCC cables too.
P.S. a load leveler makes this task a hundred times easier
Old Oct 28, 2009 | 09:16 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
I recomend removing the hood also, make life alot easier.
Old Oct 28, 2009 | 09:40 PM
z28frost91's Avatar
Car: 91 Z-28
yeah, agreed. I didnt post that, thought it was a given.
Old Oct 29, 2009 | 08:04 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
agree on all points here. also, if you are just removing the wires from the sensors label them. there are a lot of connectors that look the same under the hood, labelling will make the install much quicker.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
