350 from surburban fit 83 z28?
Old Mar 17, 2001 | 12:02 PM
virtual's Avatar
will a 350 from surburban fit 83 z28? or will i get probs with base pan and manafold?
Old Mar 17, 2001 | 05:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Externally all small blocks are the same size. You "may" have problems using a truck oil pan and exhaust manifolds.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
armybyrd
Aug 10, 2015 09:23 PM
milk
Aug 10, 2015 06:26 PM
