Help with high power swap!!!
Subscribe
Mar 18, 2001 | 11:32 PM
I am building a 400sbc with a 248deg duration .555 in. lift solid roller cam(too big?), 5.7 in. rods, 64cc 2.05/1.60 Dart heads, around 10:1 CR, flattop pistons, and my question is which induction system should i use? Miniram, superram ,or something else?
I will use nitrous and possibly eventually supercharge.
This is all going in an '89 RS auto t-tops.
Also, six speed or auto? I kinda want an auto but i like six speeds also.
Any help will be appreciated.
Thanks.
Reply 0
Mar 19, 2001 | 09:23 AM
With flat top pistons and those heads, your CR will be more like 11:1. Bad nitrous combo.
12.5cc dish with 64cc heads gives about 10.4:1, which is the combo I am running. If you're going to use nitrous you don't need as much cam, especially not on the intake side; you need a big exhaust lobe. Remember, nitrous is essentiall liquid oxygen, so you're sort of bypassing the restrictions on the intake sode; but you still have to get the spent gases out of the cylinder.
Get Comp to grind you a custom cam, with their XR270 intake lobs and their XR282 exhaust lobe, on 112° LS.
Since you're starting out with a TBI car, you'll have to buy whatever induction you use, from ground zero. The lowest buck way out would be to go with a carb unless you just particularly want FI, and if you do and are willing to spend that kind of money, take a look at the Accel Pro Ram.
What are you going to do to the car to hook all this up to the pavement?
ICON Motorsports
Reply 0
Mar 19, 2001 | 08:04 PM
I'm going to use sfc's, probably new trans, carbon fiber driveshaft, new rearend, and just about everything i can use to get traction and keep it somewhat streetable(weekend cruiser). any other suggestions will be greatly appreciated.
thanks.
Reply 0
Subscribe
