Problems starting!!!
Old Apr 1, 2001 | 12:42 PM
jovialevil's Avatar
I have an 86 camaro that had a v6 in it. I swaped it for a 1978 350ci 4 bolt out of a chevy blazer. But I used the heads out of an 86 T/A with the TPI setup. Everything in this motor is new. Its getting fuel and fire, the valves are adjusted right, as far as I know the timing seems to be correct but for some reason it dosen't want to start. The engine is turns but does not fire off. The more I turn the distributor the more it seems like it wants to start But Im almost possitive that I have the timing right.
My question is would my using the heads from a previously fuel injected car make any difference on the engine's starting capability?
ANY help would be greatly appreciated!!!!
Old Apr 1, 2001 | 04:27 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't know about your specific problem but you might be glad the car never started anyhow. Swapping 305 heads onto an earlier 350 without changing pistons will result in very high unstreetable compression. Have you accounted for this?
Old Apr 4, 2001 | 04:25 PM
jovialevil's Avatar
I had the short block rebuilt at a machine shop and they put new dished pistons in it. Would these pistons be a problem?
Old Apr 4, 2001 | 05:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The dished pistons will help keep your compression down, but those heads aren't the best performance pieces. That's not causing your no-start problem.
I'd suspect you've got your distributor in 180 degrees off. Make sure you have the #1 piston on the compression/power stroke, then check the distributor again.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
HARDWORK
Aug 19, 2001 09:11 PM
RED92
Aug 17, 2001 09:20 AM
Black Beauty
Mar 14, 2001 12:45 PM
Matt86Z
Feb 21, 2001 05:08 PM
Rylos
Jan 27, 2001 01:06 PM
