TBI to TPI ?????'s
Old Mar 30, 2001 | 10:10 PM
RyanSS's Avatar
TBI to TPI ?????'s
Any of you guys done the TBI to TPI swap?
Anybody got pics or know if there is a manual or at least a good resource to help with the swap? I just bought a TPI system off an 89 Iroc 305, I got ECM, wiring harness, fuel lines, fuel sender, manifold, runners, plenum, TB, various nuts and bolts. The guy i got it from at the junk yard said if I needed anything else off the car i could get it.
My question is what do i take off my 89 RS when i take off the TBI, and how do i tell which wires go where? Also, what sensors do i need, besides an MAF (it was missing off the donor car)? How hard would it be to convert to SD? What other parts do i need?
Any help will be GREATLY APPRECIATED!!!
Thanks.
Old Apr 5, 2001 | 01:17 PM
IROCZ88's Avatar
I've done it! Any Q's just email me at jdkchevy70@yahoo.com
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 5, 2001 | 02:27 PM
IROCZ88's Avatar
By the way, Traxion has a good article in the tech section. Just ignore the fuel line part.
Old Apr 5, 2001 | 03:08 PM
IROCZ88's Avatar
Sorry, Traxion didn't right it. It was Mauro Gembruno or something like that.
Old Apr 7, 2001 | 06:23 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I'm a little ambivalent about doing this swap. It's taken me months to finish and my car has caught on fire. A couple things to remember: you'll need to install a new fuel pump which is a huge PITA, because you have to drop the tank to get your old one out. Also, and this one is often ignored, get the throttle and TV cables off of that donor car. Your stock ones will be too short. Good luck and I hope your car doesn't catch on fire.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
