ZZ4 with TPI? can this be accomplished?
Old Apr 5, 2001 | 08:21 AM
StockBastard's Avatar
I also read the article in Super Chevy about the zz4 swap. Great article, but they mentioned that TPI would not work on that engine. Is it just a matter of PROM? Couldn't I just get one custom cut for me?
I currently have a 350 L98 with TPI and I would love to throw a ZZ4 under that TPI set up. It's been ported and matched.
Give me some ideas all.
thanks,
SB
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
Old Apr 5, 2001 | 02:33 PM
IROCZ88's Avatar
I read that article too. Notice they didn't say the price. Of course you can put a TPI on it. I don't know why they said it couldn't be done. Ever notice magazines have no knowledge at all about TPI? I saw one where they must've spent $5,000 on bolt-ons and the car only ran mid 13's.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 5, 2001 | 05:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Co-worker racing buddy here converted from TBI to ZZ3 TPI, using a mix of factory and aftermarket parts. The ZZ3 is basically the same as the ZZ4 currently available. Changing yours would be a lot less work than what he's done.
He's done some other rather radical mods, so needed a custom chip. But, yes, it can be done.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 10, 2001 | 09:11 PM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
done the swap myself. you will need to redrill your intake manifold or get a aftermarket lower that is drilled for both angles. if you have serpentine belt drive, you will need a water pump that is for serpentine drive. the car should run with the stock prom setup,,,but get one that is more friendly for the zz4. if you have the $$$$$,,the future may hold some runners or a superram. have fun..
Old Apr 11, 2001 | 12:10 AM
five7kid's Avatar
A little more detail about the ZZ4 conversion done in the mag: They were talking about the GM emissions legal kit, which so far is only certified for carb'd auto cars. What they meant by "not for TPI" is that it has not be certified as a kit for TPI. That's all.
The factory considers the ZZ4 to be "pre-'75" or "off-road use only" with regards to emissions - so, a dealer won't put one in for you. That doesn't mean you can't put one under your TPI and pass emissions testing.
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
Sanjay
Aug 12, 2015 03:41 PM
