thinking of a 2.8 to a 307 swap
Old Apr 23, 2001 | 02:51 PM
gemmefire's Avatar
alright i can pick up a 307 for cheap with 50,000 miles on it. i have a 2.8 fuel injected could i put the 307 in and get it to pass emitions in Mass. what are the pros and cons of a 307. i know its a strong engine
help me
thanks
Shawn
87 SC 2.8 stock
Old Apr 24, 2001 | 02:23 AM
Brian92RS's Avatar
Why a 307? They have a pathetic bore/stroke ratio. Plus they are not very common so parts would be expensive. If you are going to the trouble of swapping in a new motor, you should go ahead and step up to a 350, or a 383. Hell maybe even a 406!
More displacement always gives you an advantage to begin with.
Old Apr 24, 2001 | 09:12 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Why not a 307? Unless you are going to be racing, why do you need a 350, or 383? If you can get a cheap 307, then go for it. You will have more power than you did before, but not as much as a 350. Your gas milage will be better than the 350 though. It all depends what you want to do with the car.
Old Apr 24, 2001 | 09:43 PM
nestz28's Avatar
I think it's a good idea especially if you can get it for cheap and you don't want to really build it up. A 307 has more power potential than a 305 because it has a larger bore/shorter stroke.
'84 Z28 LG4 T-5
'92 Z28 wheels
153,000 miles
Front& rear suspension rebuild using MOOG parts
350 and WC coming in summer 2001
'70 nova 307, th350, all stock, 40,000 mi almost like new
Old Apr 26, 2001 | 02:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is this 50k miles since rebuild or since new? What is this 307 coming out of?
I ask because SBC 307's were made from '68 to '73 or so (meaning 50k factory miles isn't likely), and Oldsmobile 307's were made in the '80s. You don't want an Oldsmobile 307.
If it is a SBC 307, it can be made to look like an '87 305 and pass visual inspection. However, it will have to have computer controls, either CC carb or fuel injection.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Infested
May 22, 2018 11:56 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
