Brand new 300 HP 305 vs 350
Car: 1986 Z28
Axle/Gears: 4.11
So next year I'm planning on getting a new engine for the Camaro, cause I have no idea how to rebuild one. I remember seeing somewhere on a site a 300 horsepower 305 around $1000. Well if a 305 and a 350 had the same horsepower, would they still run the same? Does a 305 weigh dramatically less and save more fuel? I'd get a carborated one either way. And would I need any new parts, the car is already a stock 5 speed shifter hooked to a 305, will a more powerful engine destroy the gears or soemthing if I drive it too hard?
Brand new 300 HP 305 vs 350:
Price
Economy
Weight
Space
Power
Acceleration
Thanks for any wisdom you can give me.
Price
Economy
Weight
Space
Power
Acceleration
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Brand new 300 HP 305 vs 350
dont quote me on this lol, but i beleive a 350 is lighter than the 305 due to the displacement of block material. yeah it has a slightly larger piston but pistons dont even compare to the wieght of cylinder wall material that is present on a 305. and everything else is virtually identical. including crank shafts.
like i said, dont quote me on this, someone correct me if im wrong. cuz iv never wieghed the engines on a scale haha
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Weight: The same
Price: 350 is cheaper
Economy: 350 should do better with a smaller cam making the same power as the 305
Space: Same size
Power: 350 will be better for drivabilty, but the torque should be greater for the 350 as well
Acceleration: 350 should edge out the 305 in the torque department
HTH
Space: Same size
HTH
Transmission: 4L80E/4L80E
A 305 and 350 weigh the same.
Given the operating characteristics in the paragraph above, a 300 HP 305 may actually use more fuel than a 300 HP 350.
Basically, treat the T5 properly, and it will live just as easily behind either one.
A 300 HP 350 would probably cost less than a 300 HP 305.
Most likely the 300 HP 350 would get better fuel economy, because it would need less cam to produce the 300 HP, and therefore require less gear to get the car moving.
A 305 and 350 are completely identical externally.
A 300 HP 350 will outrun a 300 HP 305 in the quarter mile.
NinjaNife
Aug 23, 2015 11:49 AM
