84 305 into an 84 2.8?
Old Apr 29, 2001 | 10:35 PM
SkyF41's Avatar
how hard of a swap will it be? could i use my 2.8 computer? what things will i need to change? i have an 84 2.8 and i am buying an 84 305 as the donner car, will the engine go straight in?thanks.
Old May 1, 2001 | 01:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It won't go "straight in", but if you're going to do it, getting the same year and a full donor car is the way to do it (are both the same model?). You'll be changing a bunch of stuff from one car to the other: engine, tranny, harness & all sensors, COMPUTER, springs, sway bar, front mounts, all hoses, front brake line, fuel lines, fan, radiator, cooler lines, a/c, accelerator cable, cruise cable, TV cable, tach, complete exhaust, vacuum lines.
If possible, have the two cars side-by-side. Take pictures of both before you take anything apart and while you disassemble. Label everything as you take it off both cars. Things you won't have to change are driveshaft, rear crossmember, torque arm, shifter (although you may have to do these if the tranny type is different), speedo cable.
But, when you get done, it'll look like the factory put it in there. If you have to pass emissions, it'll pass.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
