knock sensor and tps?
Old Apr 27, 2001 | 10:17 AM
formula88's Avatar
sorry guys, this may be a stupid question. I'm swapping motors in my car (305 to 350), where is the tpi sensor located and the knock sensor? The lo3 is already out of the car and i pulled a punch of sensors, but i don't know what they are?
Old Apr 27, 2001 | 01:06 PM
91Firecrow305TBI's Avatar
They have an entire board on swapping motors...
Flowmaster 80 series muffler, K&N Open Element cleaner, Subframe Connectors + a lead pedal foot
Old Apr 27, 2001 | 10:00 PM
camaroguy99's Avatar
the knock sensor is on the rear lower pass. side of the block just above the oil pan. The TPS sensor is on the pass. side of the TB directly across from the throttle cable/TV kickdown/cruise control cable connections.
[This message has been edited by camaroguy99 (edited April 27, 2001).]
Old Apr 28, 2001 | 09:26 AM
formula88's Avatar
thanks for replying. Do you happen to know what kind of knock sensor I would need for a 350. Is it all the same?
Old Apr 28, 2001 | 11:10 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the 91-92 knock sensor2 are the ones to get.they aren't as sensitive as the earlier sensors
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Old Apr 28, 2001 | 03:15 PM
I also belive that the TPS is differnt for a TPI, assuming that you are switching the TBI for the TPI. As far as the knock sensor goes you will also need a new one for the 350 but I would go with what ever year injection setup you are using. (i.e. 91 Speed density TPI, 88 TBI, 88 MAF TPI, etc). The ECM is whats going to interpret the data from the sensor and thats what it was designed to work with.
Old Apr 29, 2001 | 08:47 PM
formula88's Avatar
thanks guys, i am going with a holley tbi. I have another question,? theres are two sensors by the exhaust manifolds on each side of the motor, what are they?
Old May 1, 2001 | 09:15 AM
MAXGTA2002's Avatar
well you have on the pasenger side, the knock sencer, fan temp sencer...on the drivers side you have oil sending unit, temp gage and on your exaust you have your o2 sencer hope this will help you.
[This message has been edited by MAXGTA2002 (edited May 01, 2001).]
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
