350 to 383
Old Apr 30, 2001 | 12:06 AM
MADOGIROC's Avatar
350 to 383
How much would I expect to spend if I get my completely (STOCK) engine and have it bored to a 383 stroker with performance headers
( you know the works ).
Old May 2, 2001 | 02:17 PM
88 Camaro SC's Avatar
Car: 99 Trans Am
I'm building one from scratch, and have a lot of the parts already, like the block crank connecting rods and distributor. I'm looking to spend $2500 or so on the engine alone, then probably another $750 on reinforcing my car to handle it all. Hope this helps.
Nate
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.comp
Old May 3, 2001 | 01:44 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
My cost for my labor and parts on this 383 of mine went for a total of $3100.00. This included a 2500 stall converter and a shift kit for the tranny. I only had to supply the carb. I got a great deal if u ask me. I think you should look at spending 4000.00 max
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
