Is a 383 TPI a good idea?
Old May 1, 2001 | 02:37 PM
Cruising270's Avatar
I would like to get a 383 built this summer for my car. I'd like to put the TPI on it rather than going carb. Now my question is this going to be a costly hassle, or a fairly easy thing? I definitly want to keep the TPI, and can't really afford any after market plenum. I will change the runners, injectors, and fuel pres. reg. Is a 383 a bad idea for the TPI, do you think I'd be beter off going with a 350 TPI motor and then just build that up? Let me here what you all think?
91'Z28 305 TPI *stock for now*
Old May 1, 2001 | 03:23 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
If you want to keep it TPI you will have to go with aftermarket parts. The stock system will definately keep your 383 from reaching its potential.
Old May 3, 2001 | 01:49 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Another way of doing it would be do away with TPI and go with a carb. Fuel injection aftermarket parts are expensive. You can achieve great perfromance with your 383 with a carburated setup. I have a carb on my 86 Z and I love it!
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
[This message has been edited by Big454blockchevy (edited May 02, 2001).]
RazorN8
Jan 7, 2022 11:44 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
