350 fi to carb question
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
heres the scoop, i have an 89 rs 350 tbi t5 but body rot, so i bought an 84 v6(2.8) auto, im using everything off my 89 but would like to make the car carbed cause i have the right fuel tank now, but i think i just need an intake carb and fuel pump on the front of the motor? any input is appricated
Transmission: 4L80E/4L80E
Distributor.
Sounds like you've got a complete donor car, but read the V6 to V8 swap sticky in the top section of this forum.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: 350 fi to carb question
Just use a HEI Distributor a inline electric fuel pump and a high rise intake and carb
use all cross members and keep the front springs swap out your rear end and keep all the mis parts. pedals and linkage
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
i mean dont use a a fuel pump on the side of the motor. i would use a electric one and run it in line and put a filter buy the carb.
and i said to keep all the mis parts that he will need later. springs k-member all the parts he can...
A mechanical fuel pump with return, as used by the factory, is fine. We aren't talking about a 500 RWHP full tilt racer here.
Keeping parts from old projects is a sickness. I know no cure. But, keeping the new V6 front springs that I took out of Berlinetta #1 in 1999 came in handy for Berlinetta #2 . . .
Engine: 355 chevy
Transmission: t-5
hey thanks guys, i got my 89 preety much stripped, just grabbing my clutch/brake pedal mount off of it and my new brakes off of it, im going to see if my oldsmobile fuel pump will work if not ill just go grab one and an intake and use my 72 442 q-jet
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
ive heard of people using the v6 springs on a v8 for a lowering purpose ive never tryed it so i have no say.
yea go mechanical its the easy way and cheaper then a electric way. i run a electric in the back of the car and run a single line up to the front and keep the engine bay as clean as i can.
the reason i say keep the k-member is because i actally cracked mine in a couple diffrent places with a 350 so i swapped it out with a iroc k-member and springs. but my camaro has over 300k on it so yours is in better shape
theshackle
Mar 5, 2017 06:37 PM
What are you talking about????
