rebuilding engine getting rid of computer stuff?
Old May 12, 2001 | 03:22 PM
Matt's Avatar
Ok a machine shope here in town will rebuild my 305HO for 900 bucks and they do good work. They are slow now thats why they are doing it cheap. I want to remove the computer stuff from the car. What do i need to replace? I know I need a new dist. and non cc carb, but what else? Do I need to change sending units for guages like the temp, oil, etc? I need all info on doing this so to save me the cost of someone else doing it. Thanks for any help provided. OH ya i have a 1984 Pontiac Trans Am 305HO with 5speed tranny.
Matt
Old May 12, 2001 | 08:48 PM
El Guapo's Avatar
Here is what I did on my 87 5.0 4BBL.
Replace distributor and carb.
Remove SES light.
Its that simple.
The only sensors that I have hooked up are the one's for the gauges. On my engine they are:
Oil Pressure Located top rear of manifold, single connector.
Water Temp Located Driver's side between #1 and #3 pistons
Tach Located beside Batt on distributor
Voltage Part of the plug on the alternator.
Thats all I really have hooked up.
I ran a hot wire to the carb (didnt know where the orginal choke wire was, you can re use your old one)
Ran a wire to my electrical pump.
And thats all the electricity, besides various grounds, that are on the motor.
Hope this helped some
Clayton
Old May 13, 2001 | 01:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
For 900 what does that include ? Most parts stores should be able to get you a 350 for less than that for complete engine minus intake and carb etc.
Old May 14, 2001 | 03:52 PM
Matt's Avatar
the rebuild includes new pistons, connecting rods, push rods rebuilt heads with some porting, cleaned block, machine the crank, bored.030 over, a 36000mile/3year warranty, all new gaskets, basically machine what can be machined or replace it. I am sure there is more but cant remember exaclty.
Elguapo-what carb and dist. are you useing
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:55 PM
