Carbed 305 to a 350
Old May 7, 2001 | 08:02 PM
Supercharged87Camaro's Avatar
Carbed 305 to a 350
Hey guys. Ive had this camaro for about 6 mos now, and Its got a carbed stock 305 in it. Now, this summer, once I have some extra cash flowing again, Id like to swap in a 350. But Im not exactly sure on what needs to be changed in order for me to get the proper performance I desire out of the new motor. Ive talked to a couple of local people, but everybody up here has no idea what they are talking about, So I thought Id turn to the pros. Any information that you guys can provide me with would be absolutly wonderful. Thanks.
Old May 8, 2001 | 03:59 PM
ImportEater's Avatar
Well, the swap is a direct bolt up deal. Both the small block 305 and the small block 350 are bolt for bolt exactly the same. While the engine's out, I'd go for a new set of headers, as they're much easier to change with the engine out. Other than that, just unbolt your old engine, take off the necessary accessories, etc. and bolt the new engine and old accessories back in, very straightforward. Depending on how much power you're looking for with the new engine, you may want to fortify the rest of your drivetrain, but if it's just a mild 350 you should be fine. The rest of the upgrades can be done just as easily with the new engine in the car for the most part.
Have fun.
1985 Trans Am - rough and ready -- 3" cat and primary exhaust, lowered 2", custom rust body work mild fender denting. Daily driver.
1976 Corvette Stingray - not so rough, but always ready. mild 350/th350 tranny. mostly stock till I whack the hood for the blower
Old May 14, 2001 | 06:11 PM
What about the computer in the car?
Old May 14, 2001 | 09:40 PM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
You're probably going to get very different opinions on whether or not to keep the computer in the car. I would recommend ditching it. I have a 350 in place of the LG4, and have had many problems, a few being the LG4's stock timing is 22* (not nearly enough), the carb is jetted for the 305, and the bigger cam is giving the computer fits. Maybe with a new PROM and a lot of work to the CC Q-jet, you could get it to work, but then you still can't tune it yourself. I'm gonna replace all that stuff when $$$ permits.
DG
1984 Z28 LG4/A4
Mods: are you kidding? They cost money.
Powered by Eclipse, Kicker, Rockford Fosgate, JL Audio, and MB Quart.
Old May 16, 2001 | 11:07 AM
zee28's Avatar
Car: 86 iroc
If you have to pass even a visual underhood inspection you wont pass unless you rig up dummy air tubes,wires,and use the stock air cleaner.I am stuck with the same problem.I dont have to pass a sniffer test but do fail the underhood visual every year and I still run the c/c carb and distributor.If you dont have picky inspectors or no sniffer test then take this stuff out.
~mike~86 IROC-Z
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
