vortec head help
vortec head help
. heres what happened, two of my pushrods broke through the ends of the rockers, i believe i know what i did wrong, i cut the guides down and installed new seals, installed z28 springs but i left the dampers in, i didnt realize they sat on top of the lower boss which is about 1/4" high. i believe that caused them to bind. does this sound correct? any help would be greatly appreciated
vortec head help
if i machined the guide bosses, but forgot to remove the Z28 spring dampers, which apparently sat on the 1/4" lip. could that have caused them to bind and crack two of my stock steel rockers? any help would be greatly appreciated
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: vortec head help
I would say yes, it will cause the spring bind. If you leave the dampers out will you still have enough seat pressure?
Transmission: 4L80E/4L80E
Do it right and either cut the guides or install springs made for use over them like beehives.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
