Gm Goodwrench engines
Old May 20, 2001 | 10:13 AM
Happy17yearold's Avatar
I have a 1988 Firebird with a 305 that is leaky from the head and i think is not worth investing more money(IMO).I went to Scoggin-Dickey Parts Center and looked at thier replacement engines and they have a 1965-85 Gm vehivles 350 4 bolt engine.My question is if it will bolt up with my transmission and engine mounts without much hassle.How should i go about the wiring?I plan to run carb so i will have to do some adaptations.
Old May 20, 2001 | 10:01 PM
MikeS's Avatar
It should bolt up to the tranny (assuming it is a V8 trans) and the motor mounts just fine. After all, it is a small block chevy V8. If you are gonna go with a non computer controlled carb and a vac advance distributor, you'll be able to do away with all kinds of wiring under the hood. I don't know if you plan on using aftermarket mechanical gauges, or use the stock electrical ones, but you can work that out later I guess.
Old May 21, 2001 | 02:17 PM
dude12387's Avatar
read what u said.....they have a 65-85 engine...and u have an 88....it wont fit......urs is a two bolt block......the engine that u want is listed under the caprice 350/5.7........i almost bought that one so i know
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
Old May 21, 2001 | 08:03 PM
Does gm make a 5.7 two block ?
Old May 21, 2001 | 08:48 PM
JPrevost's Avatar
Car: 91 Red Sled
I don't know what some of you guys are talking about. It'll bolt right up IF it has a one piece rear main seal. If it says that the engine is only for older cars but says it's a one piece rear main then it WILL work. Do some more research and call up Jim Pace automotive or other places and ask them for opinions.
, Jon (350 TBI!)
91 Red My website
Old May 21, 2001 | 08:53 PM
Will do..... thanxs
Old May 21, 2001 | 09:31 PM
MikeS's Avatar
my fault...i shoulda caught the one piece/two piece cutoff in there.
Old May 22, 2001 | 08:43 PM
Well i contacted the site and they recomended the 350 out of a 1993 caprice that will bolt up with out any problems....It comes with a roller cam and is estimate to make 240 hp....What else should would get me to 300 hp easy....Will headers,and carb be enough or is it more complex than that??
Old May 23, 2001 | 08:14 AM
Mark W. Winning's Avatar
Yes the motor will fit. If the new motor is a two piece rear main and your old one was a one piece, then you will just need to change flex plates. Put a new distributor and carb on it and have a blast!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old May 23, 2001 | 04:27 PM
Keith5's Avatar
Car: C1500
If you have a manual you would need a new flywheel for the 2 peice, if auto then flexplate. Another thing, the intake bolts are different, if you go carb that won't make a bit of difference since you will get getting another manifold anyway.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-velcro t-top bag
-Wonder Bar from my IROC
*****Possible future mods*****
4th gen seats, fiberglass spoiler, new paint
1985 IROC-Z, TPI Auto
-Accel Super Coil
engine and tranny overhauls coming this summer
http://www.geocities.com/krt80/
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
