ZZ4 long block VS base 350 HO engine
Old May 26, 2001 | 01:48 AM
firbird's Avatar
The zz4 block has 355hp, 405tq
compression ration.10:1
The base 350 has 330hp, 380tq
compression ratio 9:1:1
I see that the zz4 has its advantages over another i know that the zz4 has more forged steel but how much do i really need that.
I dont really want to go all out but i just want a decent car that is decent in my point of view. there is about a $1300 between them and is the few things are different internally but which one gives most bang for the buck.
Old May 26, 2001 | 01:51 AM
firbird's Avatar
25 horse power for 1300hp
Old May 26, 2001 | 02:46 AM
JPrevost's Avatar
Car: 91 Red Sled
The HO is best bang for buck. The zz4 is lighter because of the heads. The zz4 also comes with a complete roller cam setup. For less than the zz4 I did my whole swap with the HO. $3000 and I'm very happy with the results. The HO also has better designed heads, at least with intake shape and flow. They flow better under 3000rpm with a 350 than the aluminum vette heads (zz4). The HO is the same block, one piece rear seal and it's ready for a stock roller cam setup. The HO has normal cast pistons which is a bad thing if you're going to do any poweradder. Personally I don't think I'll do anything more than 100hp shot of N2o. If you plan on doing more then it's a problem. I don't think the zz4 is worth it unless you don't plan on ever touching the thing. It's a great setup but the HO can be had and built to have more power for less! Jim Pace installed a cam and used an air gap (same as RPM) which boasted hp 50 and torque by 25! They didn't even go with a roller cam setup. That was also used with a 650cfm carb. If you're looking to spend the least for the most then go with the HO, if you have a nice budget to work with, go with the zz4.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
