Building a 350?
Old May 26, 2001 | 04:16 PM
Z28BOYZ's Avatar
Building a 350?
ok guys i made up my mind i'm going with a 350. Let me know what i would need to get for it to build it up from bottom to top? And where the best place to get the 350? is it worth buying a crate engine that's what i mean?
Old May 27, 2001 | 08:19 PM
zerogauge's Avatar
starting at the bottom
350 block
350 crank
oil pan
oil pump
connecting rods
pistons(rings)
cam
timing chain and gears
pushrods
lifters
rocker arms
valve covers
intake
distributor
carb
flywheel
starter
ok i know im forgetting somethings...i think.
thats a starting place though
Old May 27, 2001 | 10:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What are you starting with? A 305 and you can use a few of the parts on the 350. A V6 and you need to plan on other stuff such as exhaust, ignition etc.
Machine work. If boring the block .030 then add about $12/hole. Depending on how much work you intend to do yourself there's even more cost.
Installing new pistons on con rods, new cam bearings. Add in the price of new rod and main bearings.
Heads? Stock over the counter replacement heads or something better? Reconditioning a set of old heads? Add in a valve job, new springs, maybe new valves and guides.
I built my big block over the winter from scratch. I started with a short block. Counting every nut, bolt, gasket, fitting etc then final total came to just over $8000 Canadian. That's buying just about everything to make an engine and install it in the car. Some stuff I already had and could reuse. Ignition, distributor etc.
It's going to come down to how much of a budget you have and what you intend to do with the engine. Buying a 350 replacement engine from a local supplier is cheap. Change the cam to something better and you're off to a good start and it should last for many miles and years. Building or buying a performance engine just takes a little planning and investment.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
