305 and 305 HO, what's the difference?
Old May 29, 2001 | 10:17 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I know it's kindof dumb, but I can't remember to save my life!
Old May 30, 2001 | 01:38 AM
robbob's Avatar
As far as I can remember the cam has a little higher lift and the heads flow a little better.I don't have any technical numbers,sorry.
Old May 30, 2001 | 08:27 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The LG4 (305) has dished pistons and the HO has flat-tops. So compression and flow and cam and I also think the HO's came with steeper rear gears to top them off.
[This message has been edited by JoelOl75 (edited May 30, 2001).]
Old May 30, 2001 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In '85, LG4's got flat tops, raising the compression and power. But, L69's still got better exhaust & cam. Before that, the L69's also had better carb secondary tuning. The heads never changed.
The standard rear ratio for HO's was better than the standard rear for LG4's, but the good gears were optional with LG4's, so don't tie the two together too tightly
Check the Tech Data page (https://www.thirdgen.org/newdesign/tech/techdb.shtml) for more details.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
