just installed a crate 350 in place of my 305. the 305 is an 86 with computer controlled carb. i also put on new chevy valve covers, there were two holes in them one for oil and i put a breather in the other, they didn't have a hole for PCV so i didnt install one. now i hear that i need one because there is a lot of pressure building up in the crankcase. do i need the PCV valve or not?
thanks
you can never have too much horsepower
thanks
five7kid
close
You should have a PCV valve. The carb calibration assumes it's there. The pressure probably isn't being properly vented with just a breather cap (although I doubt it's building up "a lot of pressure").
I would suggest using the round hole for a PCV valve, and a breather cap for the oil fill. Or, go back to the stock covers.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
the carb is now a holley 600 vacuum secondaries, does this make any difference.
How's it running? I threw that same motor in my '88 last September.
Pics of install:
http://albums.photopoint.com/j/Album...&a=6641004&f=0
Pics of install:
How does it run, Do you have any backfireing on decell? did you run this motor with the computer hooked up at all? is the car a 5-speed? And to answer your ? yes you need the pcv vavle.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
