is this a good deal?
Old May 31, 2001 | 07:39 PM
buddman91rs's Avatar
or should i do it myself? sorry fr long post but i gotta know.......here she goes:383 CID Enforcer 350 TPI
Good idle (750-850 rpm) - 3.08 to 3.70 gearing - Will work with stock gearing,
transmission, converters - Aftermarket converters (1800-2500 stall speeds) can improve
performance. 18-21 inches manifold vacuum.
350 hp @ 4800 rpm, 455 ft. lbs. @ 3200 rpm
383 CID ”Enforcer 350 TPI” 86-92 Engine – Crane Hyd cam, S/R Torquer
cyl. heads 350 hp
Long
block $4,095.00
Hi-Tork starter add $ 125.00
HD water pump - cast iron add $ 49.00
GM HEI electronic distributor w/Crane Hi-Intensity coil, curved for your
engine add $ 200.00
MSD 6AL ignition w/rev limiter add $ 189.00
Accel 8mm and 8.8mm spiral core wires, MFY wire looms, spark plugs -
custom made add $ 90.00
Holley 700 cfm Premium Series double pump carb - dyno tuned add $ 415.00
Billet alum. and braided stainless steel fuel line - Holly carb only add $ 65.00
Holley electric choke kit - installed add $ 55.00
Carter mechanical fuel pump - standard, most applications add $ 20.00
Chevy logo polished alum or black crinkle valve covers, tall
add $ 170.00
A.S.E. Steel Dampner, SFI approved 355-434 add $ 150.00
Crating & handling - 48 states add $ 55.00
Total= $ 5,678.00
HP is guaranteed to be within 1% of advertised and they dyno tune it and break it in before they ship it. the company is called american speed, their web site is www.amerspeed.com and they have engines ranging from 275hp up to 700hp....
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
RACECAR spelled backwards is RACECAR
Old Jun 1, 2001 | 08:53 PM
firbird's Avatar
i wouldnot do it but that is because i dont have the money but if you do sounds good.
Old Jun 1, 2001 | 09:12 PM
firbird's Avatar
i just dont know with all that money you probably can get a 350 to be better than that. get a
zz4 base
fast burn heads
hot cam
larger tbi
different intake manafold
and all the rest of the things such as oil pan and etc and and it would be about the same price or cheeper and it would be rated somewhere around 430hp like the zz430 i think and if you want to go a little farther you can get a mini ram and make a lot more hp
Old Jun 1, 2001 | 11:23 PM
they also have their enforcer500 383, it's carbed though.....507hp@ 5200 and 525 ft. lbs.@ 4800 torque doesnt drop below like 350
1991 RS LO3
Old Jun 2, 2001 | 08:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
455 lb.ft. of torque???!!!! 525 lb.ft. of torque???!!!! Are you looking to go fast or pull tree stumps outta the ground? Those are some serious torque #s. Is this a diesel motor? HEHE!!! You're gonna be burning off a lotta tires man.
That new 8100 big block in the 2001 Siverado 3/4 ton only has about 455 lb.ft. of torque. The new diesel has 520lb.ft. And that has a turbo!!! OK if you gotta a big dually, but in an f-body? THAT IS A LOT OF TORQUE!!!!
[This message has been edited by AJ_92RS (edited June 02, 2001).]
hectre13
Dec 11, 2023 08:14 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
ChevyZ71
Aug 13, 2015 07:30 AM
