one piece swap to two piece
Old Jun 5, 2001 | 09:43 PM
drt-rcr's Avatar
In the interest of saving a few dollars, I am wanting to swap out a new style one piece seal block (305) for an old style 350 with the two piece rear seal. The new style 305 has to come out. The cam is shot and it's lost oil flow to the top end. I have a 4 bolt 350 laying in the garage that ran great before I parted out the van it was in. I know I can get a different flex plate to bolt up to the torque converter so thats no problem. I'm concerned about the alignment of the pulleys. Is the front face of the damper in the same relative location on both engines? The 305 is still in the vehicle so I can't get a good measurement anywhere. Is the bolt pattern for mounting the front crank pulley even the same for both engine models?
Thanks, I'm sure someone on here will have the info for me.
Later,,, Matt
Old Jun 5, 2001 | 11:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As far as I know, everything should be fine.
I just swapped out a one piece 350 for a 2 piece 400 and had no problems at all.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Jun 6, 2001 | 12:15 AM
Guest
Guest
Posts: n/a
Theres nothing different about the front at all.
Old Jun 6, 2001 | 09:14 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Apart from what's been said, you should really use an internally balanced damper on your 350. Do not use the "extrenally" balanced damper from the 305 one-piece. Both mount on both cranks, the difference is the balancing.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
Old Jun 6, 2001 | 04:25 PM
drt-rcr's Avatar
I will use the damper for the 350, I was just worried that the lower pulley mounted on the 350 damper would be in a different location fore and aft wise causing alignment problems with the belts.
Thanks,,, Matt
Jorlain
Aug 24, 2022 05:11 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Poncho92
Aug 7, 2015 08:15 PM
