Crate Engine Swap -- A few simple questions
Old Jun 21, 2001 | 05:23 PM
89 CamaroIROCZ's Avatar
Ok I'm in the middle of swapping a carbed race motor into my IROC which was previously fuel injected. I have a few simple questions.
First, I'm not removing the computer so I was wondering if the torque converter is still going to lock up if its plugged in?
Second, the distributor. Since it is a non computer controlled distributor what wires do i use to plug into the HEI setup? Will the tach still work?
Third, the fuel pump. I don't really have the money for a 3 port fuel pressure regulator and i have a mechanical pump mounted on the engine already. Can I leave the electric fuel pump in the tank not running and just pump gas right through it? Or do i have to lower the tank.
And lastly, the sensors. The only sensors I really want to work are the ones in my dash. I think the engine has the temp sensor on teh drivers side that will work. But it definately doesn't have the oil pressure sender. It has a bung for it but there is nothing in it, i'd imagine it is cast with the threads but closed. Can i drill into that? Or is the pressure sending unit supposed to go somewhere else on these blocks? Its a right side dipstick 350/350 HO SBC Crate Motor.
Thanks for all your help.
Matt
Old Jun 21, 2001 | 06:05 PM
Blown 87 camaro's Avatar
Hey, first, yes you can leave the fuel pump in the tank fuel will flow through it just fine turned off. Second, all, the fitting for sensors are goin to be on the intake oil/water temp. Dont know to much about the converter, the hei and tach will work fine as long as you have a v8 in now, just use the power wires and tuck the rest awau or cut them off, :: suggestion:: since your not using any of the compuyer controlled stuff, when you have the engine out rip it all out! it will actually save you about 100 pounds and makes it look cleaner.
Cody
Wieand blown 87 camaro
Old Jun 21, 2001 | 06:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TCC will not lock via the computer any longer, as you are eliminating an info source for it. You need to get a lockup kit from TCI, Jegs, Summit, etc., or hook up a manual switch you flip inside.
The tach will work with the tach wire from your old distributor, but the connector may be different - I'm not sure about that. The mechanical/vacuum advance HEI only needs the ignition power wire to work, and the tach wire for the tach to work.
Taking out all the computer stuff saving you 100 lbs? Right. I'll grant you 5 lbs.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 21, 2001 | 09:33 PM
hmm Well i have the same car, the computer the whole harness all fan brackets when i took everything out and wieghed it was 42 pounds, take out the heater elements all ducts from inside dash and carpet padding equaled are you ready for this!!! 220 pounds
Cody
Old Jun 21, 2001 | 11:54 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
wow 220 lbs.!
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
