TPI Intake on older heads..
Old Dec 23, 2009 | 04:25 PM
shdtree's Avatar
Car: 88 IROC Z28
Engine: 385 Stroker
I'm in the middle of an engine swap (350->385) and during final assembly I ran into an issue where the center bolt holes on the older rebuilt heads I'm using don't match well with the TPI intake holes.
The issue is that while the holes line up fine, the angle of the intake hole is more vertical than what the heads are.
Any idea if there is a way to adapt the intake to fit?
I found this article and this article which basically says to just drill proper holes, so if anyone has done this, then is just as simple as making the holes a little wider and maybe counter-sinking on top for a better bolthead to intake mating?
Thx
Old Dec 23, 2009 | 05:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Apparently you have an '87-later TPI base. '86-earlier and Corvette TPI base had all of the bolt holes at the same angle. Your choices are to trade your base for the other type, or elongate the holes in your base so you can get the bolts in.
I haven't done it myself, but sticking a 3/8" drill bit in the hole and running it until you get the correct angle makes sense to me. I've heard machine shops will do the job for you as well. Just doing that won't give your bolt heads a flat surface to clamp to, fixed either by getting angled washers to put under the bolt heads (I couldn't give you a source for them, I've heard some aftermarket intakes include them), or having the machine shop put the surface on for you.
No matter which way you go, most likely the base will have to be off the engine to fix the issue.
Old Dec 29, 2009 | 11:52 AM
bblalock's Avatar
Car: 1988 IROC
Engine: 5.7 TPI
Re: TPI Intake on older heads..
How did the modification work out for you? I have the same issue.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
