350 no anti-theft to 305 anti-theft motor swap
Old Jun 24, 2001 | 05:07 PM
kndgta's Avatar
swap to 305 w/anti-theft from 350 w/o anti-theft. The car spit and sputter w/o V.A.T.S. hooked up, W/V.A.T.S. hooked up it just crank over ( no hits) We are using the 350 wiring and 305 ECM. What promblems are we looking at and what to fix the problem?
Old Jun 24, 2001 | 08:17 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If VATS is affecting your engine it simply wouldn't start, not run poorly.
Old Jun 25, 2001 | 05:54 PM
kndgta's Avatar
The motor does not run at any stage. The term of spit and sputter may have miss lead you. I should have use hit and miss. One posting I have just read states the V.A.T.S. system controls two things the start and injector pulse.
Old Jun 26, 2001 | 12:38 AM
Guest
Guest
Posts: n/a
Sounds like the vats wiring isnt all hooked up... but the no start sounds more like the timing is off.
Old Jun 26, 2001 | 09:34 AM
Drew's Avatar
When the VATS doesn't see what it needs you get nothing... you turn the key and you may get a click but thats it... If you know someone with a VATS car that works right, look under the dash, there's a large orange wire with a quick disconnect in the middle... unplug it and try starting the car.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
